Hi all.
So I completed my kit last week and it has been going fine on 3s with 3 bearings in the rear with no shims (yes bad.. none came in kit but they will arrive tomorrow) and normal as per instruction 2 bearing and spacer in the front.
Now I just upgraded my front bulkhead to the GPM and testing with the stock spacer and 2 hearings it binds up shockingly (as we know) to the point where I can't turn it by hand.
So from my understanding the below diagram is how the 3 installs work.
Stock:
So this works with bearing spacer bearing and 2 shims for 6s (according to manual)
BHB:
Grind down the tabs, use 3 bearings and X number of spacers to pack between the first bearing (held by 3 screws) and the C clip. This brings the pinion away from the spur by a few .** of a mm creating a better mesh.
Standard 3 bearing mod:
Install bearing, about .6mm of shims then 2 more bearings. This leaves a gab between the first bearing and the 3 holding screws so the pinion is a little further away from the spur.
Now... While I understand how the 2 mods work, what is stopping the "3 bearing mod" from sliding forward slightly causing a huge bind?
I am not trying to debate what works/doesn't work I just want to only 1 mod and not spend the $80 (that's how much the gears cost in Australia) if something fails.
Sent from my SM-G935F using Tapatalk
Stock:
BHB:
