This is the Nordic Crawler Design MOA chassis lineup for 2013.
Nordic Crawler Design MOA PRO COMP
This chassis is made from 1.5mm carbon fiber and comes with delrin spacers and steel hardware. Weight is a low 57g as pictured below. Link and shock geometry is a race proven design that has been run by several drivers during 2012, both local and international. The chassis will work best with 3.5" - 3.75" shocks.
Price is 99 euros, including worldwide shipping.
The LaaLaa Special
This chassis is Finnish National Champion of 2012. It is designed by the champion himself and named by our local forum members after his forum screen name. What sets this chassis apart from the mainstream now is its narrow skid plate design and different cab approach.
LaaLaa used a trick BTA setup on his XR10 and to free up space for this, his front shocks were mounted to his lower front links. This version of the chassis still makes that possible but also allows for a traditional front shock setup. You will want to use 3.5"-3.75" shocks for the front and 4" shocks for the rear with this chassis.
The chassis is also made from 1.5mm carbon fiber and weighs in at 57g with steel hardware and delrin spacers.
Price is 99 euros including worldwide shipping.
Coming soon...
The SuDu Pro
If you see something you like, but it is not quite right for you, I am always happy to customize for you. If your wishes can be fulfilled with a reasonable amount of work there is no extra charge. If it takes more time, we will negotiate a fair compensation.
All chassis's are pictured with short skidplates. I can, however, make your chassis with any size skid plate you like.
Tomi
