I think this could carry over to the super!
Yeah, I think taking these to the super could be awesome. If you used the MT gears at 6mm wide, it might be time to go higher voltage. I am not positive that small gears and shafts can hold on higher voltage and large tires but its a step in the right direction for sure.
The xr guys are going to be so jeleause, these will be the lightest axles on the market!:twisted:
Already were the lightest, now they are just cheaper. It was debatable if they were the cheapest, now thats no debate. Using these cases will save you 100's of dollars. "thumbsup"
I have a couple questions, how do you suggest coverting the berg smalls to 2.5mm, especially when using sds 300m gears? Also why is changing the mt upper link mount neccasary?
Again, I'm super stoked about this!!
If you trying to convert a stock small to the larger pin you can just drill them out with a good drill bit. If they are a Mann, SDS or CKRC small, you will need something much harder like carbide. My end mills make short work of making the holes larger. You will probably want to kill yourself if you try and drill the hardened material though.
Wow great job as always man! Cant wait to order a moded case for my rear axles! Hope those plastic gears hold up too but im not holding my breath :shock:
Yeah, I dont know what to think of the plastic gears yet. Being 6mm wider sure should help. I think they have a good shot in the rear, I would even try them in the front. Why not at $3.60?? My plan was to run plastic front and rear and then as each plastic gear strips, just replace the gear that stripped with a metal one. I would not be too surprised if you could run just a plastic 2nd gear in the front but the 3rd and 4th had to be metal. There are a lot of different combinations that could possibly work.
There isnt much question if there will be interest in these. I sent the drawing over to my CNC guy so we should have costs on those adapters soon.
I am getting quite a few PM's about these. If possible, please post your questions in here so we can all learn from them and I only have to answer the question once.
