...Somebody asked me about the Vaterra HD lower links rotating (clocking) the axle housing different than stock RTR. I didn't notice this on mine, but will check and update on this.
I've dunked a couple sets in acetone, pulled them out and cleaned with simple green and the tires and foams were fine. Might screw up some rims though. Compound dependent maybe? Can say for sure it dried the hell out of my fingers - next time - gloves!
Nice idea with the fumigation...not sure that that would do it, but if it works that's much easier.
The fumes method works good but it takes quite a bit of acetone. A bucket that size needs about an inch or two of acetone in the bottom to generate enough fumes to make it work and the tires need to be as close to it as possible without being submerged. A shorter bucket would help too.
Heat has failed to release the glue for me a few times which is when I resort to acetone.
That's why I just bought new vaterra super swampers and sold my old wheels and tires.
Ben
Are you guys happy with the stock Swamper's performance? I'm debating whether I change them or give them a chance to hopefully impress.
I like the tires a lot. Think they're one of the best all around tires. Not amazing at any one thing? But great for trail running where there is everything from grass to mud to rocks. The stock foams blow if you ask me. When I got my new wheels and new tires, I went with CI double deuce foams and they work so much better than the stock foams.
I do love my rock beasts for when I know I'm running mostly rocks but the stock tires are really good. Plus the old school pattern really looks right at home with the blazer body.
Have you dunked any Vaterra tires?
Thanks Nate for all the Information, this thread is pure Gold!!
Natedog .... Really liking this thread and your write-up's on the Ascender. Thinking about picking one up. LHS has an rtr in stock....hmmmm. Did you stick with the wraith sway bar or did I read that you went with a yeti sway bar setup?
Great informational thread as I have told you before Nate. I have used the Trepadors (1.9s) on my Blazer, they work OK in most conditions, until they get wet. If they get wet and the ground is wet you arent going anywhere with them. Using Pitbulls with a Trepador inner foam, cutdown Pitbull outer foam, and a Panther outer foam around the whole foam setup.....sounded crazy when Bruce at RC Country explained it to me but it works pretty good. "thumbsup"
It looks as though the front end is almost perfectly set up for a servo winch. Am I seeing that correctly? Has anyone done this yet? If so how does it fit/work?
I have one on my ascender. Check out my build thread.
http://www.rccrawler.com/forum/vaterra-ascender/548229-my-baby-blazer.html
There are pictures of it In post #39. It works great. I love it and have since added the vaterra aluminum fair lead that bolts to the bumper. Think you can see it in some of my later pictures. They are awesome trucks for sure!!
