C*H*U*D
No idea what I'm doing
This is my version of the "bob1961 bender". I've been meaning to make one for quite awhile and found a few spare minutes to throw this together.
I used a 3/8-16 bolt with a half inch spacer. The spacer was drilled out to 3/8" and is .190" long. I used a .250" diameter pin that is set at .575" from the centerline of the bolt...it could have been a bit closer, but works. This is with brakeline, but I plan to use a thicker walled 1010 steel tube. I had a slight bit of a kink in the first test piece...I might shorten the spacer just a tick to keep things tighter. I also want to throw a few smaller diameter bolts into this chunk of aluminum.
Thanks to Bob for posting up his original idea "thumbsup"
