Welcome to RCCrawler Forums.
i drove my truck through some water before all these mods and my body mounts and esc mount rusted so i sanded the rust down a little bit and painted it with some black rustolem paint and it turned out pretty good
a battery mount to avoid the battery hitting the driveshafts or the motor.
with out the little bracket
with the bracket
with the battery
side shot
driveshaft angle
i plasti dipped
my servo
esc box
and rx box
i still waiting for it to cure
its at 12 hours right now
is that enough time to cure or should i wait the full 24 hours?
i'll post pics soon on my electronics
so what do you think?
give me your opinions
I run one of my trucks in the mud/water alot and the bushings will not hold up. Mine were shot buy the time the second battery pack was dead. The bushings around the pinion gear were actually egg shapped and allowed the pinion gear to move around enough to strip it and the ring gear. I have since put in rubber sealed bearings and have not had any problems yet. (about 10 battery packs) I have had the truck totally under water a few times to. This is just my experience with the bushing, just might be better to fix before there is more damage. Here is a pic of what I usually run in.
venom*one
i was just like you before i built my first rig
i would read other peoples buildups and wondered what i should build.
thanks for the compliments
rockywoods
yeah that spot is great deal of funnn.
shocker
your welcome
better to be safe than sorry
ya get what im saying
KENNYKILLER14
i am probably going to my second favorite crawl spot and test it out
there is a creek to go through and the spot would be a perfect candidate to hold a comp at. if i go i will post pics.
then hoping to be able to get off work on sunday and go to the competition with http://socalrcrc.com/
axelnut1
i have run my rig under water and the bushings are holding up fine.
time will tell thou thanks for the advice
i just always thought that it was better to run bushings if the truck was gunna be run through water cuz the bushings wouldnt rust. so iduno?
for a competition
what does the course require?
i think i have a good place to host one but i havent been to a comp and im not sure how to go about this.
water
rocks
dirt
sand
tennis ball halfes
more than one course?
judges.
