MD ENFORCER
Anyone running a 12T 550 Traxxas motor in there bomber? I'm using a bomber trans in a custom frame for on road use. Anyone got an idea on the pinion size i should run with the stock 64 tooth spur?
I'd start around 12-13. Check temps. Don't exceed 160-175.Anyone running a 12T 550 Traxxas motor in there bomber? I'm using a bomber trans in a custom frame for on road use. Anyone got an idea on the pinion size i should run with the stock 64 tooth spur?
What's the difference 550 and 540?? Is it just the size or...??Maybe this coud be a good motor for you?
It is a Holmes product, and 550 instead of the 540 you burned.
http://www.ebay.com/itm/Holmes-Hobb...423606?hash=item5b24fa8c36:g:lasAAOSwrnNXP3K7
Sensored or less??if you are gonna bash with it, best invest in a brushless esc/motor...you will never be happy or satisfied with brushed...
A 550 can is longer, you can go to Holmes Hobbies site and read about the size and weight comparison - it will fit in a Bomber.
550 is what size the extremely popular Traxxas Titan brushed motors are., and they use the same mounting bolt spacing as a 540 can does.
For the sensored vs sensorless question - sensored is the way to go for a Bomber, definitely.
Basically, the Axial Yeti and SCORE Yeti-based Trophy Truck are the only vehicles I MIGHT run a sensorless in, and even then my preference would be sensored.
For a Bomber, the 540 can size in a good quality sensored brushless is the best way to go, generally speaking.
Stay in the 2200-3500kv range - Holmes Puller Pro and Redline Roc412 are the best.
A 3500kv using 3S will be very fast and torquey.
Get a temp gun and check temps regularly so you don't burn them up.
Spend a little more and get the Castle MMX ESC! The MMX has an auxiliary wire that lets you toggle the drag brake on and off (among other things). You can go fast and jump without having the drag brake interfere and then you can turn it on to crawl.Thanksfor replying guys...
Im gonna go with roc 412 and castle mmp... and buy temp gun...
I'm still searching about u4rc setup, i hope i can find something that related to my issued...
Well went to a 11 tooth pinion, and no dice. Temps were climbing to high.I'd start around 12-13. Check temps. Don't exceed 160-175.
Sent from a device in my hand that is smarter than me, and I don't know WTF I'm doing.
I am about to smoke my motor. it's whatever comes in the rtr. when crawling, applying torque and getting through technical stuff, it will smoke pretty predictably. If I am trail driving or in a faster-pace more wide open area it's all good. but if the tires get spinning and i'm real technical crawling I need to watch it that I don't overheat the thing.
3s battery stock rtr motor. It's on the way out though. I'm thinking 3500kv brushless with some fancy esc. Or maybe 2700kv. Thoughts? Anything to watch out for that I'm not gonna see when I'm researching this? Mostly crawling. Has to be solid crawler, but go fast once in a while is fun. Dual purpose kinda deal.
