angrchair
Bomber Build log
Currently installed parts list:
Aluminum Interior Panel
AMF Racing Axial Bomber RR10 Aluminum Differential Protector (Wraps Around Pinion)
AMF Racing Axial Bomber RR10 Aluminum Skid Plate
Axial EXO Rear Light Bezel and Radiator Set
Axial 64T Steel spur gear
Castle Mamba X & 1406 2850kv motor and Castle Link Y adapter
Crawler Innovations Double Deuce medium foams, comp cut front standard rear
DMG Radiator Mount
DMG RR10 Bomber Spare Tire Mount
HeyOK KOH light kit
Pitbull Growler 2.2 Tires
RC4WD 1/10 Warn 9.5cti Winch
RC4WD Mudslinger tires
RC4WD Warn 1/10 Wireless Remote/Receiver Winch Controller Set
Robinson Racing Hardened 12T pinion gear
Savox SA-1283SG
Savox SC-0252MG for shift servo
Scalerfab rock sliders
Spektrum DX5C radio with SR415 4 channel receiver waterproofed
SSD 2 speed trans
TBR Top Plate - Axial Bomber (w/ optional LED light sets) - broke and removed the light bar
Team KNK hardware
Vanquish 2.2 KMC XD Series Wheels
Vanquish 25T Servo Horn - 20mm
Vanquish Brass knuckle bushings
Vanquish C-hubs and Knuckles
Vanquish Currie Anti-rock sway bar
Vanquish Currie F9 front
Vanquish Currie F9 rear
Vanquish IDF Wheel Hub Kit .350"
Vanquish Incision 38/13 gears front
Vanquish Incision 43/13 gears rear
Vanquish Incision Spools front and rear
Vanquish Incision 1/4 Stainless Steel 8pcs Link Kit
Vanquish motor cam
Vanquish motor mount
vanquish Rigid 4" light bar
Vanquish Trailing Arms Clear Anodized
Vanquish VVD V1-HD axle shafts
Vanquish HD rear axle shafts
Wertymade RR10 Bomber Stainless Servo Winch Plate
DMG Radiator Mount
HeyOK KOH light kit
Savox SA-1283SG
SSD 2 speed trans
Team KNK hardware
Vanquish motor cam
