My 2013/2014/2015 Losi Sporty
Decided to give the Losi axles a try this year
Axles have fmj mod,rear has standard worms,modified Underground Crawlers D-mount and DLux weight holders. Front has HD-worms ,BWD aluminum servo/battery mount,Losi alu 20 degree hub carriers and alu knuckles and Blue Monkey knuckle-weights.
Lunsford lower links with RPM rod-ends and DLux delrin link sliders,4mm carbon rod upper links with Revo rod-ends, Traxxas alu balls.
Traxxas dampers with Mini-T springs,JeepinDoug cups and Wicked Wolf RC caps.
Hot Racing XR10 Carbon chassis with DLux cross braces.
Homemade "gearbox" with just pinion and spur,shaft above motor and Axial WB8 driveshafts.
TLR 22 frontwheels with SLW 850 hubs, Crawler Innovations foam and shaved Rovers.
Hi-tec HS-7954SH servo, castle BEC, Tekin ROC412 3100kv, Tekin RS ESC and LRP fan.
Axial Hardline body.
