Motoworx racing 2.2 channel locks
motoworx
Canon City
New April of 2019 the*2.2 slant face channel lock 12mm Hex wheel.
Whats New:
This 2.2 wheel is designed to accept Motoworx Racing 12mm 8 hole-2mm detachable hex hub which are included with the wheel
Backspacing is adjustable with the 12mm 8 hole hex extenders in .200" increments.
Motoworx Racing .200″ HEX HUB EXTENDER (8 hole bolt pattern) |
2mm hardware is used on the beadlock rings and for the hex hub mounts. (included)
The outer ring screw hole pattern on the 2.2 MXR* wheel*has a 16 hole or 8*hole mounting option. This allows*for the use of an 8 hole outer ring in comp situations for quick tire changes or a 16 hole outer ring*for scale effect.* 2.2 bead lock rings | Product categories |
Weight reducing channel is cut into the outer diameter for weight savings without structural compromise
Compatible with Motoworx Racing center caps.*Motoworx HD\LE Center Cap |
Sold Individually. Be sure to add the desired quantity to your cart.
Included:
2mm beadlock ring screws included
2mm hex hub screws included
The 8 hole inner*ring is included with each individual wheel purchased.
The desired 16 hole* or 8 hole outer ring must be purchased separately in the 2.2 RC Bead lock Rings section of the website.
The 12mm MXR hex hubs are included
Not Included
Motoworx Center Caps
Motoworx Scale hubs
Hex hub extenders
Outer beadlock ring
Tires
