micro racer
After running my truck a few times over my rock pile, it was quickly apparent that I would need some rock sliders. Besides holding a couple of boxes on each side, the sliders protect the fuel tanks from being ripped off. Unfortunately, I lost a fair bit of ground clearance; however, as they do in fact slide over the rocks, a good blip of the throttle normally kicks the truck over.
In the picture above, you might notice that the middle tire is compressed almost all the way to the rim. I might need to talk with Crawler Innovations about some foam to better support the tires, since the front goes flat just sitting on the bench...
Right now I am at a bit of a lull in chassis building; I need to order several parts before I can start the rear bed and roll cage as well as the front bumper. In the mean time, I will continue finishing up the body work. Last week, I received the final parts tree (grill and headlight buckets) that I needed in order to finish the body, save some custom work for the exhaust stacks and mirrors.
Finally, I mounted my radiator and housing to the back of the body.
I still need to sleeve a few of the all-thread links, and the front lowers need to be completely redone (all-thread and sleeving) because they are too short. For my rear winch, I recently saw a thread posted about a (relatively) new K2 winch by KMS, one that outputs 480 oz-in of torque, which seems perfect for the bed winch of my 6x6. Along with the bed winch, I will be running a less powerful front winch, probably a KMS K2 or K3 180 (keeping costs down and the main winch is supposed to be in the rear) depending on where I will mount it.
