My 6 year old son and I have spent a good amount of time recently bashing around my Stampede and his Slash on our local hiking trails. I finally decided last fall to step up to an actual crawler, and picked up a TRX4 kit. I grabbed a Hilux body for it and started building.
I had a great time running it up and down the rocky trails nearby, but of course I couldn't keep from tinkering with it. Started simple with the Yeah Racing axles, and then threw on a Savox steering servo and BEC.
I recently got a Long arm lift kit to try out, and modified it a bit as I put in on, based on some other posts I had read:
- cut off the travel limiters
- replaces the springs with the traxxas "white" .29 rate springs to soften the ride and get more sag
Messed around with in the backyard, and relatively happy with the results. It still sits pretty high, a bit more sag would be preferable, but I'm not sure if there are any softer springs that would fit. I'm hoping moving to metal portals will help lower the COG some more. I'll take it to a rocky trail later and see what happens with some actual crawling.
