Members' Rides - No talking
Berg V3. Pretty much stock except I modified a servo mount that I have to fit my Hitec servo. I also swap the steering linkage to make it fit. Stock tires.
Holmes Hobbies new Stacked mini BRXL
Holmes Hobbies 13T Crawlmaster Pro (X2)
Castle BEC
Hitec HS-7980TH servo with aluminum servo arm
Futaba FHSS receiver
Robinson Racing pinion
3S lipo
Chassis: Axial Scorpion
ESC: Mamba Max
Motor(s): Novak Fifty-Five
Servo(s):Hi-Tec 645-mg
Trans: stock axial
Axles: stock axial
Tires: Losi Rock Claws
WB:
Overall Width:
Diff clearance:
Center Chassis clearance:
Overall height:
HSP Crawler 1:8
APEX esc
roc lox 4.0 tires
traxxas titan motors
savox titanium servo
Junfac servo saver
Truck Base : Axial Wraith Poison Spyder
Body: Custom made all aluminum body to allow scratching and dents. Allllll about scale!!
ESC: AE-2 ESC with Drag Brake
Motor(s): Holmes Hobby 35t Expert Torque Master with 14t pinion and 87t Spur
Servo(s): ProTek 150S
Trans: Stock digg capable
Shocks: 110mm King coilovers modified to single spring with 40w oil mounted in a different location. Flipped link/shock mounts
Lighting: 5" Led light bar with custom made underbody rock LED's and Bumper Lights. (all lights ran on auxilary power (batteries) Light bar and rock lights on one circuit, bumper lights on a seperate circuit)
Axles: Stock Housings with Vanquish Axle shafts
Tires: SEDONA
WB: 14"
Overall Width:13"
Diff clearance:1.5"
Center Chassis clearance:3.5"
Overall height:10"
"Blu Balls"
Truck Base : Axial SCX10 JK
ESC: Tekin RX8 GEN2
Motor(s): Trinity REVTECH 4XS 3800kv
Servo(s): Holmes Hobbies TrailMaster BLS HV400
Trans: RRP Hardened Aluminum Gears, Traxxas Jato 32p spur
Axles: AR60, Hardened steal ring/pinion
Shocks: 110mm King Off-road Shocks
Tires: Pitbull XOR - Vanquish Rockstar 2.2" rims
Lighting: 6" Vanquish Rigid LED bar w/ Poison Spyder JK mount
WB: 13"
Overall Width: 12.25"
Diff clearance: 1.5"
Center Chassis clearance: 3"
Overall height: 9.75"
Hey Folks sorry its been so long since i been around... but summer is here and things get pretty busy... but gues what.. here is a pic of my latest creation .. this one is quite the little beast...
AK CRAWLERS.....
RS10 AXLES all the rest is custom made
main.php
main.php
Went out to the local favorite spot tonight.
Good times.
And my pro-line shock cap stopped coming off after a fix using a piece of Ziploc bag....
Wraith
ESC stock
Motor 35trock crawler modified
Servo savox
Trans stock 87 t spur
Axles stock
Tires HB white dots. Weighted wheels
Wb 14
Width 11 7/8
Diff clearance 1 1/2
Overall height 8 7/8
Custom narrowed front and custom fast back. Free mods!
Gmade R1 tube chassis
Maxstone 10 front axle and trans
AX10 rear axle
Gmade Transition shocks
Maxstone 10 ESC
Holmes Hobbies TorqueMaster Expert 27T
Spektrum radio
I just got rid of all the green anodize including the green beadlock rings, shocks stayed anodized red.
Truck Base : Tamiya Bruiser frame
ESC: Tekin FXR with CC BEC
Motor(s): RC4WD rebuildable 35T
Servo(s): Savox SA-1256TG
Trans: Built Axial transmission connected to an RC4WD Hammer transfercase
Axles: RC4WD Yota I axles
Tires: RC4WD 1.55 Invader tires
WB: 11 1/2"
Overall Width: 8 1/4"
Diff clearance: 1 WHOLE inch
Center Chassis clearance: 2 1/2"
Overall height: 8"
Truck Base : rc4wd tf2
ESC: Holmes hobbies br-xl waterproof
Motor(s): Holmes hobbies 35t torque master pro
Servo(s):steering savox 1230, transmission hitec metal gear, transfer case hitec he 225
Trans: rc4wd 2speed r3 with ax2 heavy duty output shaft
Axles: rc4wd Yoda 2
Tires: 1.9 proline tsl sx
WB: 11.5"
Overall Width: 9" 3/4
Diff clearance: 1 1/2"
Overall height: n/a
My MRC Landcruiser (CR01) build
- Stock electronics
- Chassis custom dropped and stretched to accommodate CR01 body. Approx 10" wheelbase
- Mudslinger xl tires
- Black Losi wheels
- Homemade rubber fender flares
- Pissed off driver
- Waterproof stickers
etc, etc...
Losi Mini Rock Crawler CR01 Landcruiser update pics...Also, my alternate body (custom military buggy, New Bright rollcage)
Added a bunch of stuff...fun fun
