TheHeadHunter
Done nothing much but find the direction I want to go in by reading up a lot of great stuff here this summer (literally).
Finally I attempt an AX10 build out of my RTR purchased 1 month before the ARTR came out:-( ...but hey at least I got one of the last HPI Bugs to cruise in style 8).
What I want to attempt here is a build low in CG, and also a well balanced all around rig (and I need lots of trial and error and help to get there).
Being inspired by some great chassis builders; Bender,Franky Rizzo, TCS and many others here "thumbsup" I have decided to start from the chassis.
Warning: This is kind of like a mock up of what I had imagined would work and not the final chassis design or overall stage of the rig!
Chassis>>>>>testing TVP out of 2mm aluminum (braced)
Axles/Tranny> RTR AX10 (plastic links is perfect for the mockup IMO)
Shocks>>>>> HB
ESC>>>>>>>>Sidewinder
Motor>>>>>>>Brushless 1000KV Outrunner
Battery>>>>>>1500mAh 11.1V
Tires>>>>>>>>Tamiya CR-01
Here are a few photos before some questions"thumbsup"
the chassis is longer at the bottom than the stock one but I'm using the stock skid, so the two screws in the middle are holding the skid which marks also the original bottom of chasis length
Wheelbase is a tad long at 13.5 which brings me to my next questions:
1.Should and can I buy shorter links for the AX10 or are for example some aftermarket TLT links shorter by about 13mm? I would rather compromise link lengh over chassis length...
2.Is the belly too low? Would bent links and taller tires get it just up there?
3.Anything else that doesnt look right?
This rig most probably wont be entering any local Japanese comps (if there will be any out there ever).
But I want to make it work either way...
Finally ...This is not a "So what do you think?" thread but if you feel to ,go ahead!
Shocks>>>>> HB
