ser3100
Actually just by looking at the driveshafts between the two the yetis is much longer
I haven't gotten around to changing the battery plug yet, but my plan is to just remove the integrated plug and have an XT90 plug sticking out through the hole. The integrated plug should be easy enough to remove, there's only two screws holding it in-place.
Yeah, but I have XT90 plugs on all my full-size batteries. I really don't think it will be a problem to have the plug dangling out of the hole; it can't possibly be worse than my current setup, which is to have an adapter plugged in and the entire battery cord flopping around.XT60 is best connector I've found. Shouldn't be too hard to swap EC3 for XT60 and bolt/ShoeGoo the XT60 in place. "thumbsup" Sweet truck too!
I have a Savox 1258 in mine. It's perfect for this and super fast! Just make sure you use a glitch buster or bec.
Anyone know if this will work? Or am i just buying the stock unit over again?
Losi 232004 Heavy Duty Differential Housing & Internals: Baja Rey
Do you recall the part number of the Losi servo arm you went with?
Ordered from Horizon today, $405 shipped. There is a 10% off coupon if you google "horizon hobby discount code"
