For the mirrors, we found the indentations for the holes to be a hair off making our mirrors to low. Not a big deal, but before you fully drill them out, we suggest double checking the locations so you do not need to make them oblong like we did.
I've been using that window cut technique for a while. Gives you all the trim without the funky sticker tint
Has anyone ever tried a wet apply method with RC details? As a sign maker we always used a dawn and water solution on acrylic or glass surfaces to squeegee out any air. Funny thing is I've never thought to try it on my lexan bodies until just now. It takes a few drops of dawn to a bottle of water. Allows you to maneuver the decal around then squeegee out air.
I remember doing that on "decals"...Has anyone ever tried a wet apply method with RC details? As a sign maker we always used a dawn and water solution on acrylic or glass surfaces to squeegee out any air. Funny thing is I've never thought to try it on my lexan bodies until just now. It takes a few drops of dawn to a bottle of water. Allows you to maneuver the decal around then squeegee out air.
Yes, it works great. Was just going to suggest that
Brandon.
How do I get extra stickers?
:mrgreen:
The bigger stock ends might be more durable but without testing there is no way to know their merits at the moment.
I will mention, the shop H2 SCX10 trackbar has been on the same m3 rod ends for years, without issue. It weights 9lbs and we are not gentle with it.
We've trashed lots of link rod ends on it, but never the trackbar.
M3 rod ends are usually just fine, unless you start putting them on multiple angles. So as long as the trackbar threaded ends are co-linear, they hold up well.
What we will do is offer one that is a direct replacement and accepts the M4 rod ends ... and another that is for builders.
Bending is not all that complicated, but like I said, keep the ends co-linear so that the rods ends are in a 90* push/pull without side loading.
"thumbsup"
Our thought is that people will end up lowering the ride height, and the extra compression may become necessary.
"thumbsup"
It does work well. Window tinters also use that method and works flawlessly.
