The time has come for Dakar Rally Truck inspired build #3! This time around we are using the Big Shock Liaz as our inspiration. The chassis is the same as the K-55 with some tweaks here and there to fix a few small things and accommodate for a different style cab and box. The parts list is just about identical to the K-55 with only a few changes to the suspension, mainly the shocks. There really is no timeline for this build, but it is already under way and should start coming together pretty quickly over the next few weeks!
Chassis
Custom 3/8" Aluminum C-Channel
Electronics
Tekin RX4
Tekin ROC412HD 4200kV
Tekin T-440 Servo
Tekin T-120 Servo
Tekin Power Cell 2S 8400 X2
Spektrum SR515
ESS One Sound System
6V UBEC
Lots of LEDs
Transmission
Axial SCX10-II 2 Speed
Front Axle
Vanquish Currie F9 SCX10-II
Vanquish Knuckles
Vanquish Knuckle Bushings
Vanquish Spiral Cut Ring/Pinion Gears
Vanquish Spool
Vanquish 12mm Wheel Hex
Incision VXD Shafts
Fast Eddy Bearings
Rear Axle
Vanquish Spool
Vanquish AR44 Axle Shafts
Fast Eddy Bearings
Wheels & Tires
Vanquish 2.2 Method 105s
Incision #7 Hubs
RC4WD 2.2 ZXL 5.2" Tires
Suspension
GMade XD 103 Shocks X4
GMade XD 103 Piggyback Shocks X4
Vanquish Bomber Trailing Arms F/R
Vanquish Currie Anti-Rock Sway Bars F/R
Incision Bomber Rear Upper Links F/R
Chassis
Electronics
Tekin RX4
Tekin T-440 Servo
Tekin T-120 Servo
Spektrum SR515
6V UBEC
Lots of LEDs
Transmission
Front Axle
Vanquish Knuckles
Vanquish Spool
Incision VXD Shafts
Fast Eddy Bearings
Rear Axle
Vanquish Spool
Fast Eddy Bearings
Wheels & Tires
Incision #7 Hubs
Suspension
