Let's see your Losi!
Cape town style: South Africa
My vexatious Losi Comp Crawler.
Specs:
Eritex moa kit
Integy 45t lathe motors
Castle Mamba Pro
Punk Dig
Turnigy 1300ma 30c 4s lipo
Hitec hs-7995
delrin sub skid
HB Rovers
Crawler InNovations foams
DNA Thrashers
Losi alum. axle goodies (thanks AJ)
Here is mine...
Specs:
Goat 2s w/ 18.5 turn motor / 12t pinion
Aluminum C's, spindles, rear lockouts, servo tray, servo mounts and upper link mounts.
Comp Claws on the front, Rock Claws out back. (HB Rovers on it now)
Crawler InNovations foams in both the Claws and the Rovers.
Steel DIG plates
Swapped ends on the LCC. Front axle is now on the rear, rear axle in the front (basically the tranny is backwards)
ESC under the hood, battery in the back. Receiver on top of the MSX12 DIG servo
Minimal wiring...ESC to motor wires are 1 inch long
#57 shock valves
40wt shock oil
Yellow (2.0) springs on the back
Stock springs on the front shocks
8oz weight in the front (5oz in Rovers)
2oz in rear (1.5oz in Rovers)
Mad Dawg Tuber
and countless hours wrenchin' and wheelin'
Here's mine! Specs are
-Mamba Max Pro, Castle 10A BEC
-Novak 18.5 with 14mm Rotor
-Hitec 5955TG Steering Servo Hitec 225 Dig Servo
-Thunder Power 3S 1350mah packs
-DX3R
-Vanquish Revolver R-2's with White Rovers and Stock Foams
team suzuki/losi
my suzuki inspired LCC
18.5 novak goat
dx3
hitech metal gear servo now has LNC light kit
