Let's see your Losi!
Got some updated pics of mine, taken with a real camera instead of my cell phone!
Here's a shot of mine from my first comp with it.
Eritex MOA
Eritex Comp Solids
35t Integys
Castle Sidewinder
Castle BEC
Hobbico CS-170
DX3R
finally got a decent lookin body on this thing so here we go
losi cc with lrp brushless 21.5 crawler motor and esc
hobbico steer servo
bec
losi mini servo
losi shocks of course with white springs in front and yellow rear 45 wt oil
2 set hbi rovers white 1 set on stock losi rims 4 oz front 2oz rear other set on hr rims 4oz front 2oz rear "hr rims are heavier so its like runnin 8oz in front 4oz rear"
3 cell lipo 1250
losi grappler body
dx3r
ckrc front axles "no problems with them"
aluimum lock outs, c hubs and knuckles
shortin front end by 1/4 in or so, legthen rear by little more then 1/2
i think that about covers everything"thumbsup"
DX3R
Sidewinder CC BEC
Novak Goat 3S 18.5 Ballistic Motor
Mayhem Double Phattys Grinder Rings
Custom lexan battery tray
Custom mounted cooling fan
3S Lipo
Losi LCC
Mayhem Engineering LS 2.0 chassis
Futaba FASST
Mamba Max
35T double
Max Amps 3S Lipo
Hot Bodies Rovers blue + Acer foams
Eritex adjustables
Associated B44 cvd mod
I put a new shell on mine today. "thumbsup"
Eritex Inc MOA kit
Dual 35t Integy motors
Castle Sidewinder
Thunder Power 2250mAh 30c 3s
Eritex Inc Comp Solid beadlocks
Truck: Losi Comp Crawler
ESC: 1/10th Sidewinder
Motor: Traxxas Titan 21t w/out motor ring
Gearing: 12t pinion
Tire/Wheels: Stock wheels and tires
Weight front/rear: Front 7.75oz Rear 3oz
Body Stock Grappler
Servo: Hitec HS7955tg
Batteries: Flight maxx 3s 20c 1300mah
Castle BEC
Radio: M11
Stock setup right outta box.
sidewinder
ccbec
cobalt puller 480 12t w/12t pinion
Hitec 7950th
Hitec 225mg dig
Rocksmith Eng steer kit
RcBros low cg servo plate and mount plates
Losi servo mounts (easy off'ed)
Hot Racing aluminum C's, knuckles, gears
Traxxas progressive springs in rear
Vanquish DH Comps 535front 485rear
HB Rovers (blue)
DX3S
esc - Tekin FX-R 45T
pinion - just got it, so trying to figure out which pinion to use (16t is too hard on the motor
Radio - Futaba Magnum 3PK Super
Losi MSX12 Digital dig servo
Futaba S9157 steering servo
Battery - Common Sense RC 2s 2000mAh Lipo
Upper Track Rod position - Bottom
Shock Arm Position - C
Shock Mount Position - 5
Wheels - stock tires and rims
http://www.facebook.com/album.php?aid=99312&id=535800428&saved#/photo.php?pid=4282077&id=535800428
http://www.facebook.com/album.php?aid=99312&id=535800428&saved#/photo.php?pid=4282076&id=535800428
http://www.facebook.com/album.php?aid=99312&id=535800428&saved#/photo.php?pid=4282055&id=535800428
http://www.facebook.com/album.php?aid=99312&id=535800428&saved#/photo.php?pid=4282054&id=535800428
the posting rules tell me i cant attach photos, so this is the best i could do:D
album.php
album.php
album.php
album.php
tried for a rusty scratched matte scale look w/noob painting skills think its not bad boat tailed sides w/ heat gun and made dents and flared fenders for shockspring clearance filled side body holes w/ lexan and thick ca glue just looks like some bad bondo work on the doors and made top mounts now i have trouble finding 2 body pins instead of 4 painted a rust color underneath then a white on top and blue over that all after scuffing the hell out of both sides of the lexan then used dremmel to bring out the primer and rust layers arround the "dents" now i dont mind being on the roof so much as it accentuates the look running a ..
sidwinder
futab t3pm
integy 55t
3s lipo
castle bec
hitec hs7955tg steering
hitec 82 mg dig
3 oz ea front
1.5 oz ea back
bat tray lower links
new worms new cvds
thanks to help on here sweet dig set up on radio
Spektrum DX3R
Novak Goat 13.5
Airtronics 94780 steering
HiTec225 Dig
2s2p 2600 lipo
CC BEC
Vanquish R-2 wheels
HB Rovers
Pro-Line Crowd Pleazer body
HB Rovers
Goat
Spektrum DX3.0
Don't have pics of it on the rocks.
