How much were you wanting for them?
I'd do $30 if I didn't have to ship them.
HELP??
Just got a new mamba max pro for my wraith...installed and powered up, when i try to calibrate i just get a quick flash of all led's and starts beeping continuosly. Will not calibrate...I've checked all my connections...all setting on tx..trim, epa, reverse...tried two different tx/rx setups...different batteries...Same result. Any suggestions??
flysky gt3b and tried the stock axial ax-3...yes have steering
plug the ESC signal into channel 1 and see if it responds since that channel is tested as working. Make sure all end points and dual rates are maxed and trims are centered.
according to Castle.....
rapid beep says its waiting for full throttle. Are you holding full throttle while you power it on?
Didn't see it mentioned, but are you running a bec?
And which one if the MMP's are you running?
I think there's been a few model changes within recent years.
The 1 cell version requires a bec to work.
