Hal
Nice looking setup. I think the ESC could be moved to the front between the front cross braces. It should help with your weight bias better and offer a bit more protection. IMO it helps to have as much of the "have to have" weight up front. Have to have = servo,ESC,bec (if needed) and battery. It helps keep the rig lighter. Only add weight when and where needed to get the correct ballance. Mine is around 65% front and 35% rear. My MOA is closer to 70/30 and I am very happy with both. I have a small cheap scale I use to weigh it. Put front on weigh it then put rear on and weigh it. Simple math will give weight bias. My driving prefferance may be different than yours but this works for me. I found on the ESC if you cut your braking way down it will work best. The worm drive axles have natural braking affect. Too much and you will be doing backwards wheelies (stoppies.) It also puts a lot more stress on the driveline. I still am thinking you will like the hotter motor but that may be just me. I also have the heavy duty diff gears in the front. It helps to "overdrive" the front end. With the front wheels going faster than the rears it stops it from going over bacwards on climbs so much, also better turning. I hope I dont come across as a know-it-all, but a lot of this I had to learn the hard way. I wish someone had told me some of this. Tribal knowledge is a good thing, learn from others mistakes when you can. Although my stubborn side sometimes just wants to "do it my way" wrong or right. Looking good so far. Did you get a look at youngbloods rig yet? Let me know what you think. It is deffinately different. Keep us posted.:wink:
