Ya get that pinion . I’ve been looking for a LCC since I got my LNC still haven’t found one and can barely find the parts to make a LCC so I been making most of the stuff
Ya can never have too many spares....ive got my nc on sale,want a new b/l power combo and obligatory spares.Keep an eye on Ebay. I have both a LCC and LNC2.0. I was able to get all the hard to find parts for the LCC as sparts just took time. The hardest to find was the Losi Dig Servo Arms (LOSA4038 and Battery / RX Trays (LOSA4032). Have another box worth not pictured with new in package HD worms and stuff. Never know what my future LCC/LNC plans will be so I stocked up on the spares just in case. Planning on taking my LCC to the next level this spring and maybe converting the LNC to an LCC - the dig.
Sent from my BLN-L21 using Tapatalk
Got em....Horizon in germany had em...hope my calcu....guestimations are correct...bought 13 through to 16 for good measureYa get that pinion . I’ve been looking for a LCC since I got my LNC still haven’t found one and can barely find the parts to make a LCC so I been making most of the stuff
Cheers H20haze.....your the second person to mention Robinson to me.....ive been told they offer a custom service also.I bought a few Robinson Racing Pinions from AMainhobbies:
https://www.amainhobbies.com/robins...-gear-3.17mm-bore-12t-rrp1012/p454461?v=11677
and installed the 12T on my LNC. I haven't tried my RR 14 or 16T yet, but they will fit if the 12T does.
FYI, they make a harder pinion starting at 16T and up:
https://www.amainhobbies.com/robins...steel-pinion-gear-16t-rrp1416/p454466?v=33747
The 12T esp is cleverly made. It doesn't have a step after the gear teeth, followed by the set screw. It tapers after 6mm approx to a larger "toothed diameter". And the tapped hole for the setscrew is then recessed. I had to line it up precisely with the spur (also taking into account axial play of motor) so that the "larger dia taper" edge comes within about 1/3mm of hitting the spur. But it works! no binding, or any wear that I can see on the spur.
The pic doesn't do the tooth profile/recessed setscrew design justice, it's hard to see.
I would recommended switching over to a sensored brushless. Also, make sure to upgrade your CVD's to the V3/LNC style that has the clip around the CVD pin. Also, check out the 21:1 HD worms that come with the LNC. The LCC 25:1 worms had issues.
A 17.5t is good crawling speed. A 13.5t has enough low end speed but can still has enough speed to jump up ledges but also likes to break axles......These were old tekin redlines. If I was buying a motor today I would check out the offerings from Holmes Hobbies or the ROC412 from tekin.
According to tekin, the 13.5t was a 3500kv and the 17.5t was a 2500kv.
Tekin - Product Archive REDLINE GEN1
I know some of the cc's did have quality issues with the worms but only comp versions as far as im aware,my race roller diddnt have the issue according to Losi's own part numbers.I've heard of this clip before. On my LNC 2, I had tape covering rear CVD, but not in front...and it fell out in sand. I found it half buried in only about ten min tho. For this "clip" can you give a part # or pic or..?
There's a ver 3 of the LNC?
I've also installed the old 1:25 Losi stock worms in rear with same # of shims (I calipered the 21T HD and 25T and they had same lengths). I did this so the front would be overdriven. I bought a spare set and also have the version made by HR which is nitride hardened and 25T. Are you saying that these will self-destruct on me? Am using 12T pinion, stock 35T motor brushed, 3S lipo.
B/l system is on wish list but Ive a couple more models to get hold of this month one may have a Novak b+l combo in it already,ill just have to wait n see.I would recommended switching over to a sensored brushless. Also, make sure to upgrade your CVD's to the V3/LNC style that has the clip around the CVD pin. Also, check out the 21:1 HD worms that come with the LNC. The LCC 25:1 worms had issues.
http://www.teamtekin.com/redline_gen1.html
The fella I bought mine from runs a couple of cc and hes pretty clued up,he offered me a full set of v3 cvd's with the roller so I took them,still in packets for now till one goes pop.
Its not been driven outdoors yet even so not keen to go for over/under drive set up just yet but see what I can turn up for the skip this month.
Im surprised so far,my 35 runs cool as currently...ive still to drop one tooth on pinion but its running like a dream....might be a different story once the can has sucked in some crud n dust but for now its v good if lacking a little in bottom end grunt.This is for the axle shafts not the drivelines......Photojunk has broke all the old threads but this post shows the differences.
http://www.rccrawler.com/forum/team-losi-comp-crawler/236046-question-v1-v2-v3.html#post2341211
In summary,
V1 - Broke easy, The shaft was tapered at the ball and the pin slot grooved into the taper which made it weak.
V2 - It was still tapered at the ball but the pin slot was much better now. So strong enough. Horizon offered free upgrades from V1 to V2. However, I don't think they ever installed V3's from the factory for the LCC but the LNC got the upgrade
V3 - There was no taper at the ball and there was a spring retaining ring to keep the pin in. This shaft was beefy. However, the pin was still weak. Dlux used to sell chromoly replacement pins and there was also "Gunnar Pins" which I think was made out of piano wire? Anyways, V3's are good shafts and I would recommended upgrading the pins if you can.
Yes, the first LCC's to hit the shelves had the gears cut in the wrong direction. However, even the corrected gears were weak. The spool is fine but the pinion would wear out and break. I went through about a dozen worm pinions until DLUX started selling Chromoly worm pinions. Those were the bees knees.
The HD gears, are pure beef and I also noticed my motors ran cooler as well.
Make sure to watch your brushed motors temp like a hawk.
So Krazedbuilds made an axle plate that was CF and moved servo over and had battery mounted on left. It went off their website this week, but Erik says it's a supplier problem and he will sell them again end of next week. $15 USD plus shipping. I think the LCC and LNC share same axle housing, so many of the screw holes might match up. Here is link which doesn't go anywhere presently:
http://www.krazedbuilds.com/opencrt/losi-unstuck/losi-front-axle-plate
