Joywrex's Creeper Build (First RC ever)
I desoldered the motor and reset the esc to the rx (it blinked in all the right ways and the green light would go on when i pull the trigger etc) It still does the same thing. I also looked at the rx settings and nothing is set to forward 100% or something like that...:evil:
WTF
im woundering if this problem isnt with your ESC, but your radio its self. what radio system r u running? and what kind of servo r u running? my problem is with my radio no having a very good connection with the RX on the truck.
Im using a flysky fs-gt3b
The servo is Savox.
Tonight I will try to move the receiver around in the truck to get better signal...
I started a thread under electronics for this issue:
http://www.rccrawler.com/forum/electronics/343624-esc-when-turned-will-only-move-forward-100%.html
I just bought a modded up losi micro crawler. I have some BIG plans for it.
I would say that is not normal. I even had to try it with mine......nothing near that.
You either have a bind in the tranny or your mesh between the pinion and spur is too tight.
Putting the power directly to the wheels (by hand) and the bind is making the chassis twist in the direction the driveshaft is turning.
I'd start by popping the inspection plug off the back of the trans and check the pinion.
check that rear axle too. it looks like your rear axle is not centered with the chassis and that could cause other problems later on. i'd say check your axle pins also. if not i would deff check the trans like what sledrig said "thumbsup"
Yeah I need to adjust the lengths of one of the rear links but I have been waiting for the new RMDW chassis so I have been procrastinating on working on it untill then. After much painful troubleshooting I ordered an FXR esc. my rooster runs like a chicken with its head cut off...
The pinion gear meshing seems fine.
Sorry we couldn't help you reach a definitive answer to your ESC/motor issue.:cry:
You will be happy with the FXR, it's tiny!"thumbsup""thumbsup"
I've just been waiting for the new XR chassis for the last couple months.
I am waiting for that before I redo the links.
I cut the memory foam part of my double douce foams. That's about it...
I've been so bored I bought a losi micro!
i contacted the machinist through Facebook....he was getting back to workin on Paradox parts at 430 this morning...i hoping for good news by the end of the day today or possibly tomorrow...as soon as I have good intel ill let you know
Cheap
Fast
Good
You can only pick 2..........:shock::roll:8)
My machinist is one of the best...he just had some life issues that got in the way of forward progress...I know Ive been there...many of you have seen Mr. Murphy give me a run for my money...the machinist had to take care of his family first....thats all I really know. I cannot and wont ask anyone to be patient...not when they have spent money on parts and havent seen a return yet. I will say this though...I dont think anyone is chomping at the bit like I am.
Way cool. cant wait two get mine i got the red one still dont know what esc two get i am thining of the vonom vsc it has 320 Amp.or the Novakrooster crawler."thumbsup"
My machinist is one of the best...he just had some life issues that got in the way of forward progress...I know Ive been there...many of you have seen Mr. Murphy give me a run for my money...the machinist had to take care of his family first....thats all I really know. I cannot and wont ask anyone to be patient...not when they have spent money on parts and haven't seen a return yet. I will say this though...I don't think anyone is chomping at the bit like I am.
My comment was not directed towards you (I believe you knew that), having dealt with shops before as well as doing my own side-work, this was the basis for my post.
