Ittybitty's BERG
Hmm good question...heavier than your rig...and heavier than Monstergt's (4lbs) too. I'll brush off the remnants from the comp and get a weight later tonight.
I will be under 4lbs once I put it back together, maybe I will not need the tuning rings up front.
I would at least try a soft inner tuning ring or a medium. My Rovers are clapped inside and out. Removed all internal ribbing. They may wad up to much in the front with just a soft outer ring.
My Rovers are totally clapped out as well, I have been running just the soft outer up front since I got the tires, no issue. I am thinking going to softs out back will remove the last bit of hop the rig gets when I put the wheel speed to it.
So I've had a problem with the DLux rear upper link mount loosening up between the transmission and the mount...probably my fault, but in either case it wasn't a good situation so I ordered some of the brass inserts from McMaster yesterday and they showed up today. Here's the result...
Cool thing #5 about delrin parts.... Easy thread repair "thumbsup"
Wow it's been a long time since I posted in here. I recently received another package from EddieO with some more HP for this rig :twisted:
They is be:
KR 4 Mag Cans
30t Skewed HHK Arms
Standup Brushes
7.5mm Comm
Epoxy Balanced
