Interest in Rally?
just read the rally article in rc driver, and loved it so it inspired me to get a tc3 and workout, and im converting it over to the rally specs.
so with that said does anyone know where a guy can find the conversion parts, ebay is sucking and stormer hobbies is out of stock can anyone help me out with some info.
R2J and MThead are the resident TC3 experts. I would hit those two up for all the details.
They both have build threads in the non crawler section as well.
The one in the air and the blue Subaru are both TB01s. The Ford in the back is an old electric Traxxas 4 tec.
New Tamiya XV-01
Check this sumbitch out :twisted:
''XV-01 PRO Chassis kit
Motor suspension features only enhance the covered some in the dirt to the chassis structure was sealed radio box that are friendly to dust resistance The rally chassis multi-purpose can accommodate the road and various other parking and off-road, the belt drive PRO Chassis Kit to realize is standard equipment Motor production item is sold separately spot OP TRF damper parts, such as strengthening and universal shaft driving belt stable by placing the front overhang.
Tamiya kit assembly XV-01 PRO Chassis Kit Electric RC 1/10 [tentative name] is a limited item.
Off-road and parking, a multi-purpose chassis rally appeared.
Adopted the suspension only increase the dust covered some excellent chassis structure, in the dirt.
Driven layout is put on the front overhang and weight of the motor is belt drive, run a certain sense of stability even realize.
The PRO chassis kit was equipped with a standard OP enhance TRF damper parts, such as a belt drive shaft universal and improved, the quality of the ride.
Finished in compact gear box while keeping the front motor split into upper and lower motor is adopted considering the maintainability of the gear.
OP was prepared as off-road parts to the road surface changes from moment to moment is essential, a slipper clutch also.
Radio box (chassis)
Dust-proof radio box that are friendly to the most anxious in the off-road riding.
Also equipped with four-wheel inner fender, each hatch is screwed.
The space is also equipped with ESC-like duct removable cover, we have also taken into account design and exhaust heat.
The battery is the battery access hatch chassis from the bottom.
As an internal structure with a packing cover, radio box and leads, in the hatch has also been completed at the connector connection.
Adopt a long steering tie rod steering proven in touring car.
Structure difficult to lock the discharge port is provided, such as pebbles at the bottom of the chassis.
Only type suitable for off-road riding with improved suspension arms also covered some also.
Rear suspension rear suspension geometry was adopted reversible.
Stroke in addition to securing a higher ride height in mind off-road riding, you can quickly adjust the toe angle as well as another body in the suspension mounts.
Part XV-01 PRO Chassis Kit as standard:
TRF damper
Universal 4-wheel shaft
Full Ball Bearings
Enhanced belt drive
Aluminum Turnbuckle (Blue)''
Looks freakin awesome"thumbsup" please let us know when they are available. I love the front mounted motor, that will help when breaking hard into the corners getting the front tires to bite and trying to get the back end to kick out.
Assuming the battery is placed near the back of the chassis, it should be pretty balanced. Only thing is with a belt drive down the middle like that, the weight of the battery will be off to one side quite a bit I would think.
What I got out of that:
Im anxious and it's screwed. :lmao:
Either way Im getting one.
Nice find Rubba."thumbsup"
Got me searching the net for it now.:ror: Found an estimated released date of July and a rough estimate of value (in yen) of about 350.00. Hopefully the price comes down a little, regardless it looks pretty slick.
i got board over the Memorial Day weekend so I got started the backyard rally track. Planning on a variable surface course. I have the basic track layout started and sprayed about 3 gallons of weed killer. Now just waiting for the weeds to die!!! I've run the trophy truck on it, its a little bit tight but I think it will work great for the rally cars. I will have to dig out a few small tree stumps out and work on a banked turn. I am also working on making a little bit bigger takeoff and landing ramps for the cross over, maybe add some traction surface before the takeoff ramp.
<a href="http://s20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/?action=view&current=WP_000683.jpg" target="_blank"><img src="http://i20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/WP_000683.jpg" border="0" alt="Photobucket"></a>
<a href="http://s20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/?action=view&current=WP_000690.jpg" target="_blank"><img src="http://i20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/WP_000690.jpg" border="0" alt="Photobucket"></a>
<a href="http://s20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/?action=view&current=WP_000691.jpg" target="_blank"><img src="http://i20.photobucket.com/albums/b232/PaulyBGood/RC%20Backyard%20Rally%20Track/WP_000691.jpg" border="0" alt="Photobucket"></a>
<iframe src="http://www.youtube.com/embed/Wbk1q__D4js" allowfullscreen="" frameborder="0" height="315" width="420"></iframe>
