WRMorrison
There's a local guy here selling a fairly new Sharp mill with digital X, Y, Z and power quill/table for 5K. Wish I had the money, that's a pretty sweet deal.
JasonInAugusta said:I'm using that Sherline like clockwork. :lol:
Lathe + Vertical milling column = WIN! :mrgreen:
im using a CNC Barron from cncmasters.com
paid 8500 for everything. Software, tooling, etc. Its CAD CAM compatible!
GREAT machine. have done multiple transmissions. accurate to the .0001"
Got a link, I will prob end up going with a tormach mill.I've been around CNC machinery all my adult life and the Barron CNC is the smallest machine I would consider for what you guys are doing with the RC parts. A smaller machine could be used but rigidity and HEFT is a must!! The mill is based on a solid imported mill that's been around for years. The manual version of the mill, available from Grizzly and others would also be a great addition to anyones shop.
Thanks, that's too large for me, I gonna have fun trying to get my tormach to fit .I've seen them at the tool shows. I mill a lot of titanium and tool steel so I went with a bigger machine. Tough materials can really beat up a smaller machine. If all you're going to mill is aluminum and softer material the Tormach will work great. I have a machine made by CNC Automation. They are put together by a company in Mass based on an import machine just slightly larger than a Bridgeport. Instead of the quill being the Z axis as on most machines like this, the CNC Automation actually drives the knee instead. This allows the quill to be used manually, like a regular mill. It also provides much more Z travel.
http://www.cncauto.com/ProductInfo.aspx?productid=M3X-3V-KNEE-MILL
It's great for the very limited production and one of a kind projects that I do. It can also be used as a manual machine and with the balls screws, it's amazingly smooth! I also have access to a larger, enclosed machining center if needed. For me it was a big investment but it SHOULD last forever.
