BlueMonster,
Ace has some great info posted here. ;-)
But I want to add my .02 cents. :lol:
Ace said:
I just remembered:
Center drills, used to start a drill on location. Otherwise the drill point will deflect a little and the hole won't start where you wanted (thou or three off). Get a few of the small sizes (1/4" shaft or so)
Quick explanation
Center drills are used with the lathe to drill a hole in the end of stock for mounting between centers in the lathe.
They are designed to drill a small diameter pilot hole followed by a 60° countersink that provides a bearing surface for the 60° point of the lathe center. Center drills are also used extensively with the milling machine to accurately start holes.
http://www.lathemaster.com/PIECECENTERDRILLSET.htm
But, I quit using them for starting holes I want to drill, after having that small tip break off in my work a few times. I have since switched to spotting drills.
Spotting drills are very short and rigid, and are made with angles of 90, 118, and 120 degrees. They have a very narrow chisel edge and a very small web to ensure accurate starting. 90 degree spotting drills are recommended for use with drill bits up to 118 degrees, but some people prefer 118 degrees.
In use, you will set up the machine's depth stop so that the spotting drill will penetrate just enough to leave a hole of the desired final diameter. If you use a 90 degree spotting drill, this is very easy to calculate (diameter is twice the
depth). Also, if you go just a bit deeper, you can chamfer or countersink the hole at the same time.
Both kinds can be seen at:
http://www.use-enco.com/CGI/INPDFF?PMPAGE=23
Ace said:
Grab their 1/4" edge finder.!
When you buy one, get two because you’ll get in a hurry one day and break it. :?
I have been using a Wiggler/Center Finder made by General that is practically indestructible. After my son broke two of my Starrett edge finders, I bought it for him so he would keep his hands off of mine. Now I find myself using it more than my Starrett.
http://www.littlemachineshop.com/products/product_view.php?ProductID=1823
Below is the General Wiggler/Center Finder. Even my son couldn’t break this. :mrgreen:
http://www.toolpeddler.com/s389-4.htm
Ace said:
Endmills:
Get a few, you'll be breaking them learning on a cnc!
That's fur sure :lol: :lol: :lol:
