mjderstine
SuperShafty.com
i'd go with a bec too. is this thing a lot bigger than anything else you ever had before? if so the esc bec won't even be close to enough to handle both servos.
I run the Castle BEC Pro(20amp). Lots of guys run two 10amp BECs. The pro just puts it all in one package. I do think that two of the 10amp BECs will be smaller than the pro though.
http://www.castlecreations.com/products/ccbec.html
My pro dosn't even plug into the RX. It powers the servos direct just like the diagram Rick posted. The yellow signal wire is the only thing that plugs into the RX from the servos. Two 10amp BEC would do the same thing as the pro. For best performance, you need one BEC per servo. You could try what Cordwood said and power the front and see if the RX can handle the rear but I bet you'll be happier in the long run with two or the pro.Ok I only have a 3ch rx/tx. If I got the pro I wouldnt be able to use it. I would have to put both servo's on one ch. and I dont want that. If I use the cc bec, will that only give power to one servo?? I didnt think I need 1 bec per servo,I thought it was just a matter of put it in there and you had better power to what ever you run. Im lost....:shock:You all have actualy confused me on this..What I thought was not right I guess. Maybe I should quit thinking.. Is there a good bec like with pics..lol I like pics.
Thanks for the confusion...:shock:
Looks stable as hell. Love that puller too don't yuh"thumbsup"
Aside from lack of tire traction how do you like the sure beef of the TF Super? Looks great man.
One heck of a spot too. Lucky dog.
Ok so I got the beck hooked up. I have it set up as showed in the instructions. I went out for a test and decided I need to try and hook the bec up to just front and try to run rear off of the esc like you all said to try. I will probly be getting another bec for the rear but Im just testing different things since I have never owned one. Anyways I got a really bad video for you to actually see it run.
I will explain now that I used my phone and 11yr old daughter to make this happen..lol forgive me now. I was so bad I didnt even edit it.
http://s941.photobucket.com/albums/...ew¤t=photobucket-4236-1316124932709.mp4
Thanks
And again sorry for the bad vid but it was spur of the moment at the park after one kid got out of school and we were waiting on the other. LOL and did I mention it had stoped raining for about 1 1/2hrs today and we got done just in time for it to start again....
I've been super busy... I'm glad I was able to catch a glimps of your progress. Looks freekin AWESOME!!! I might sugest softening up the foam in your tires for better traction. Great job building though!!!! I hope I get to see it in person some day. "thumbsup"
