WHITE-TRASH
So typical rc4wd they half ass engineer something and then come up with a fix it kit that's screwed up too.
The ax2 is back together with the upgraded output shaft and the kit comes with 2 shims to center the shaft. If you use both it locks the shaft up. If you leave one out it allows movement and bearing failure. Luckily I keep shims on hand so it's fixed properly.
Also found a use for an HR sway bar link. :lol:
