If your Traxxas 2075X oem servo is not responding to any input and the gears are fine, chances are it just got hot and blew the smd fuse. I stumbled onto a video of how to check and bypass the fuse. The servo in the video is a standard 2075, it is the same as the 2075X the only difference is the 2075X motor has a little more power and metal gears.
Fuses are put in place for a reason !
Soooo..... use this mod at your own discretion.
Lots of components can fail inside servos, this appears to be the most common problem. If you ohm out the fuse and its open try this mod. If the fuse is good....toss it and get a new one. Its not worth the headache trying to diagnose the rest of the components.
I have a brand new 2075X traxxas sent me still in the bag, opened it up and the 2075X does indeed have the smd fuse as 2075 does in this guys video.
<iframe width="560" height="315" src="https://www.youtube.com/embed/XphjzSc_DnI" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
