Has anyone done this mod with cms? I have cms and have ordered the parts to do this and was a little concerned.
All 5 of the rigs I've done this for had CMS. Not sure what your concern is
Thanks for the replies. I kind of figured it was the unis binding, because the xr mod has sooo much throw! I will just drive around it for now.. Im headed over to check out the dlux unis now. 8)
Higher Res pics and or the dimensions of the parts machined?
x2...can't see much in the little pics.
I've replaced the image with a higher resolution "thumbsup"
nyimak ahh oom "thumbsup"
:mrgreen:
Just machined some delrin beef tubes per the OP as well as traded my Vanquish SCX10 stage 1 kit for an Axial XR10 aluminum kit (Just waiting on shipping now)
All that's left is a set of universals and i'm in business.
One more question. Which Ackerman arms do you recommend? Vanquish look longer than the axial arms
So everything came in and i was able to use my steel beef tubes.
I did create a little too much slop on one of the filed down ends. It still works, just more slop than i should have. Don't drink and grind kids
Also, i am not getting full steering (under power) to the right. I get full steer to the left though. I thought it was a weak or dying solar D772, so i swapped in a buddies HT-7954 (both at 7v) and same issue. If i pick the truck up, i get full steering lock both ways.
Guessing my steering arms (Went with axial aluminum) are to blame?
