Just wanted to thank you. This is faster and more accurate than xacto blades or my dremel.
Makes me wonder what else I am doing the hard way
Doe this work with the lexan bodys or only on the harder plastic bodies.
yes, works with PVC. someone (maybe in this thread) mentioned plumbers use this trick all the time in tight spaces.This is a cool technique, i hear you can do this with pvc too?
Is it the same way just have to drill a hole in the pvc this time? I need to do some fine work with pvc and a big saw just won't cut it (har har har a pun)
