Hobby king "thumbsup" if you search .8mm bullets they come up.
Josh
Didn't think of looking there. Thanks
Sorry I missed this. I scored mine on eBay
No worries. I did try looking of the Bay but had turned up nill.
Thanks guys
Josh
Are you going to run the Zener Diode mod?
+1.... not that I know everything, but, never heard this one...... :shock:Haven't heard of this one yet. Have a link for the mod?
Zenor diodes only let current go one way within a specified voltage. Not quite sure what this mod does.
Zener diode - Wikipedia, the free encyclopedia
I updated the first post, it is recommend to install a piece of foam in between the two boards for protection.
Thanks for the diagram. I'll just stick to my, "ESC BEC powers the RX, external 10A BEC powers the servo direct."8)
Note: in the diagram, I would think the ESC to RX red wire should be removed??!!
PS.....ahhhhh....this is the mini?
I will contact JRH for an answer....but, the internal BEC is not "smart", thus will supply a voltage regardless from my understanding.Charlie...what John was saying would happen with things hooked up as shown in the diagram is that the ESC's bec would not provide power to the Rx unless it sees a "need", therefore leaving the red wire hooked up wouldn't be a problem. At least that's what I remember from reading through his thread.
What is the size of the heat shrink tube that you used?
Looks great William "thumbsup" What are the dimensions of the package, particular the height ?
Nothing will happen. Just alittle water barrier to keep things safe if you find some water on the course "thumbsup"
They are clean, I did use flux to tin the wires and wasn't sure if the coating wouldn't stick to any residue. Also, I picked up silicone conformal coating. Is that the right type? Thanks. "thumbsup"
Conformal coating what's a good brand?
