TheLetterJ
Word on the streets is that setting the PWM frequency to 16k makes it run quieter.
Try 4k or 8k
Much quieter
Sent from my Nexus 6 using Tapatalk
That noise is feedback for me. I used it to gauge how much throttle I have to use and also to determine when the truck is bound up.
I should give silent a shot though.
How much throttle you have to use is determined by how much trigger you have left to pull!
If that works for you then you have better muscle memory than I do.
I run all mine at 8K, no issues.
The BEC voltage has burned out one light controller though, waiting for it to do the same on the cheap servos. :roll:
:lmao:
I think I stepped my main rig back down to 6v, seems to work just fine for the ds3218 servo.
Love this esc - best thing going. Especially when you compare it to a stock dynamite that came with the ascenders.
This is my first QuickRun ( going into the SCX10.2 ) but not first Hobbywing; have several esyruns in other applications.
Having trouble getting the Prog card to talk to the 1080. ESC flashes like crazy and the card shows dash lines. I have let it sit for some time but no joy.
Do I need to set the up the unit with the Set button first ?? The EasyRuns just worked with the card seamlessly.
Prog Card instruction folder says brushless, the card says its Brushed but the instructions only apply to lining up the card to the ESC.
Im stumped.
