HH Cobalt Puller- Reborn page 35!
I ordered my 16T as soon as I saw them hit the site a day or 2 ago. "thumbsup"
Out of curiosity, what tradeoffs do the magnum design make compared to the regular Crawlmaster? Price is an obvious one and I would guess increased amp draw as well but are there others?
yep, slightly more heat and lower runtimes. The runtime change depends on the average load, which in an average crawler is on the order of a few amps (2200mah battery lasting an hour). If you are burning 5ah per hour or in 15 minutes, it wouldn't be nearly as noticeable to add 0.2a more losses as compared to 2.2a per hour discharge rate.
The same can be said for any "upsizing" of active motor materials. A Puller stubby (17mm long rotor) has lower no load than a standard (26mm long rotor), which has lower no load than an XL (36mm long rotor). The smallest motor will produce the least amount of power and torque, but net the longer runtime if the average amp draw (load) is low where a sizable portion is made up of no-load loss. Same example of 2.2 amp hour discharge rate, the stubby will have the longest runtime all else equal. Go to a faster rig like a U4 race, and the average load is far higher, which puts no load losses as a smaller fraction as compared to copper losses, in which case the standard or XL might give longer runtimes because they can handle a higher load at a higher efficiency point.
The take home of this, is that it is always a balance to find a motor with "enough" torque for the tough spots without impacting efficiency at really low loads. The monkey wrench is the human variable. When people upsize a motor, they typically use the extra torque too, so maybe runtime goes down or maybe it is unchanged because the efficiency boost under peak load is higher than the smaller motor.
