Help with Drive shafts
corvette1311
vancouver canda
:oops: my trx4 high trail desided to snap a drive shaft and im cant find any metal upgraded ones online. i realy dont want to put stock ones back in,
does anyone know of an aftermafket drive shafts that will fit a trx4 high trail?
thanks
<script src="moz-extension://3c3fe6a0-701b-493a-8517-a2c66ca11ab1/js/app.js" type="text/javascript"></script>
would (312 mm (12.3") wheelbase trx4 drive shafts work on the high trail with 336 mm (13.2") wheelbase? or would i need bigger ones ?
thanks for the help "thumbsup"
Look for ones for the Defender and Tactical, they are 12.8. Front might be a bit short though.
Really, most of the extra length is in the rear driveshafts. To be sure, measure from pin to pin compressed and extended and use those numbers to find shafts that fit. Most should list the range they work in.
