mikemcE
Why does my Savox Servo on my TRX4 turn right but not left?
Incorrectly installed horn, end points or sub trim set wrong, bad servo.
Hang up and Drive
Hang up and Drive
Could be something in the servo gears, TX settings, binding on the links... Most like the servo is dead or needs new gears. Stock servos in crawling don't have servo savers so they take some heavy apuse that stock plastic traxxas gears can't withstand.
__________________________
Handy gearing spreadsheet
The low end resolution of the 880 esc is not as good as the crawlmaster motors. So you would be better off with a trailmaster 21t for the extra torque imo.Quick Q: getting a TRX-4 sport kit soon, HW880 on 4s.
Would the Crawlmaster sport 15t 550 work with stock gearing? Need just enough wheelspeed to pop over stuff. It's the only 550 sport they have in stock where I'm getting the TRX.
But yea either is fine.The low end resolution of the 880 esc is not as good as the crawlmaster motors. So you would be better off with a trailmaster 21t for the extra torque imo.
Is the crawlmaster 550 15t too hot in a trx6 on 3s 2200 spektrum smart packs? I have 5000 50c packs, but really like the difference when running the small packs with the 21t trailmaster.
I can gear down to 9t pinion if need be
Hi there John,
Have been looking at the SWM2 and wondered if it would be man enough to power a snub nose in a lightweight comp rig?
I had a thread about this a while back but no definitive, pmd Robert and he thought it may be possible but recommended asking if you had tried this combo and your thoughts?.
Thanks
Why does my Savox servo on my TRX4 only turn right and not left?
Thats probable the idle beep, you turn it off with a castle link.I have an scx10.2 with 1800kv revolver, sidewinder 4, shv500v3 and a Traxxas tqi radio and receiver. The sw4 beeps every ten seconds and most of the time the servo twitches the wheels when it beeps. How do I stop this?
As a side note, this is my first quality servo and first brushless setup. Can’t say enough about every HH product I’ve used so far.
Motors turn in either direction, just swap the wires. Look at the pinion, clockwise or counter clockwise from there. Sealed can motors should have zero timing and can turn either direction. Rebuildable motors can be swapped by switching the wires as well. If they have advanced timing you just need to adjust that for the corresponding rotation.Which direction do you look at the motor to determine rotation?
I have one question, why aren't we getting these amazing videos here on RCCrawler??
https://www.facebook.com/HolmesHobb...07645/?__so__=permalink&__rv__=related_videos
So is this motor okay for most light "go fasts"?
Also if we order one can we get a sticker with that lil' tugger logo? that would be awesome!
it's not really for go fasts, maybe a go medium
I have a futaba 4pls radio, a castle creations motor esc combo, mamba X, and a futaba R304sb-e receiver. I have linked them up but what I found was in forward throttle there is low power and a one second delay. In reverse no delay and good power. It's as if reverse and forward are switched. I've tried swapping wires on motor changing settings in esc via cc link. Any suggestions or advice would be greatly appreciated.
