Posted this a coupla days ago but so far no help.
Ive got a Futaba 4PM and Axial simple LED controller. Can anyone walk me through the steps necessary to be able to switch ny lights on and off? The owners manual doesn't mention this and I'm at my wits end. LED controller is currently plugged into the channel 3 port. Thanks.
First, if you want to remotely control/activate/deactivate accessories using a Futaba Rx, you're going to need to get some Futaba CPS-1 units. I'm currently using two in my Axial Capra...one to control the headlights, the other to control the lightbar (yes, that means your need separate CPS-1 units to control each separate accessory on the same vehicle). These are how Futaba Txs remotely control accessories (lighting, winches, etc).
The physical connection part is easy: You first plug the CPS-1 into whatever channel you're using, then you plug the lights (or whatever the accessory is) into the CPS-1. While I don't have a 4PM, I do have the 7PX, so programming settings should be extremely similar.
Start by going into 'Menu', then 'CPS mixing'. In the CPS mixing sub-menu, you should find the 'CPS mixing' choices (CPS mixing 1, CPS mixing 2, & CPS mixing 3). Going into #1, first turn mixing "On", then make sure the "Operation mode" is set for 'ON/OFF' (it's only other mode is 'Flash'). Finally (at least in the CPS mixing menu), set the "Control" to 'Mixing switch' (there should be 7 possible choices, with 'Mixing switch' being at/near the top of the list).
Now, back out of the 'CPS mixing' menu, to the main 'Menu', and go into 'Linkage menu' (which should have 2 pages). On the second page, go into either 'Trim/Dial select', or 'Switch select' (depending on whether your planning to control the CPS-1 using a DT switch, ok a PS switch (I'd recommend a PS switch, thus 'Switch select'). Within the 'Switch select' sub-menu, set whichever switch you want to control the lighting with to "CPS mixing 1". In my Capra, I've got PS3 controlling the headlights (via 'mixing 1'), and PS2 controlling the lightbar (via 'mixing 2'). At this point, you're almost done...but not quite.
You'll notice two option sub-options, labeled "Dir." and "Type". Depending on which PS switch you assign the CPS-1 to, "Dir." will probably be 'Nor.', but it might need to be 'Rev.' This swaps the on/off positions, in regards to which ('on' or 'off') is the default when turning the Tx on. Additionally...again, depending on which PS switch you're using...the "Type" will need to be either 'Nor.' or 'Alt.'. This is because some switches default to a standard "on/off" (press & release to town on, press & release to turn off), while others default to "off", and are only "on" when the switch is pressed & held. For example, on the 7PX, I've set PS2 to 'Alt.', because it is the second type ('Alt.' changes it to a "standard" on/off switch), and PS3 to 'Nor.', because its default is already a "standard" on/off.
Hopefully, these directions aren't confusing...and, hopefully, the 4PM menus are the same as the 7PX menus. Even if the two menus aren't completely identical, hopefully they're similar enough for you to get the programming properly set. But, before your can do any of that, you'll need to get at least one CPS-1. Initially, my plan for the Capra was to control both lights with a single CPS-1 (you can daisychain up to 6 lights on a CPS-1). When I ordered mine, knowing I'd eventually need more, I ordered 3. However, as I mentioned earlier, I decided to control each light individually, so now I only have one CPS-1 remaining, and I'll need to order more (for current & future projects).
~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
