HahnsB2
Been many years since I've posted around here. Haven't really touched the hobby in a few years. I gathered a bunch of parts for this build years ago and never got around to it. I broke my wrist riding my trials bike a couple months ago and figured it would be a good time to build this while I couldn't ride.
This is an 2002 Hasbro GI Joe 1941 Willys. The actual scale I've managed to measure when comparing to the real thing is 1/6.5.
Parts list so far:
Fusion SE 1800KV
Hitec 9381 Servo
Flysky G7P
Wraith transmission, 13/52 gearing
Vanquish Rockjock 70s (centered rear) with underdrive gears in both
VP Scale knuckles and inner Cs
VP Ti rear Wraith links
Home made front steel links
VS4-10 3 gear skid
Scratch built steel frame
Scratch built titanium cage
RC4wd 1.47:1 transfercase
SSD 2.2 10 Hole beadlocks
225 SLW hubs
Stainless brake rotor weights
RC4WD Rok Loxs
CI 5.75" Double Deuce Foams (soft front, med rear)
RC4WD 1/8 scale dual motor winch
RC4WD super scale 90mm shocks (junk, Dravtechs on the way)
13lbs with battery so far. Overall gear ratio is 50:1.
Started by hacking away all the excess plastic on the bottom of the body and making the frame rails. The frame is 1/2" square tubing that I ripped down the middle with a band saw. It was then pie cut and welded for the bends. VS4-10 skid because it's readily available and the link mounts are built in.
Next was the cage. Original plan was the use 1/4" steel rod, then I had the idea of using titanium to save weight. I found a really good deal on .265" Ti rods in 10-12" lengths. I knew I needed a couple pieces longer than that, but decided to try it and see if I could weld them end-to-end. The main hoops that run front to back are welded in the middle and it's pretty hard to tell, very happy with that.
I was pretty happy with how the cage was going but realized it was a bit tall.
I cut down all 4 corners of the cage about 3/8" and welded them back together.
The transmission and servo mounts took me a long time to get right. I had a unused 3300KV Puller Pro Stubby and a HH BLE ESC that I planned to use for the project years ago, but realized I didn't want to package an ESC somewhere. These 2 in 1s didn't exist when I planned this project years ago, I made a dimensional stand-in for the Fusion and used that while I waited for it to arrive
Next was the front bumper, I stole this straight from @Szczerba as I always loved the Willys he built.
I then finished up the cage. The front "window" bars and door bars are 3/16" and the passenger handle is 3mm. Total cage weight came out to exactly 1lb.
No Country for Old Men is one of my favorite movies, when I saw another Willys build with an Anton figure, I knew I needed one for mine
More bumper and fender protection/slider work, again stolen from Szczerba.
The chassis.
Why a Hitec servo when there's a million cheaper brands with more power these days? It draws only about 2 amps, plug it directly into the receiver, no other wiring/BEC bullshit needed, and the battery life increase is very noticeable.
The panhard mount I milled from solid steel.
Tied the rear cage mounts into the frame.
I glued tiny 1206 warm white LEDs to the edges of the gauge cluster clear plastic to illuminate it.
Also gave it headlights and marker lights, all controlled from a super cheap Amazon light controller.
Painted with Tamiya Gun Metal.
First run I used the tires from my CXT since I didn't yet have foams to hold up to the weight. Since the 5.75 foams I now have are oversized for the 5.5 Rok Lox, they are now plenty firm for the weight.
Parts list so far:
Fusion SE 1800KV
Hitec 9381 Servo
Flysky G7P
VS4-10 3 gear skid
225 SLW hubs
RC4WD Rok Loxs
The chassis.
