re: Guido: Scale TTC Bronco 2012 NWSC Rebuild 49" IROKS(Paint and interior updates pg53)
Good point Harley. But this is the bearing at the Chub, all it does is support the inner shaft. I don't see how it supports any of the rig's weight. The weight of the rig is carried by the bearings in the knuckles.I would definitely stay with the 5x11. Just going down to a 5x10 bearing you cut the load handling about in half :shock: These heavy scale rigs already EAT bearings under big power. I believe a 5x11 will hold about 80+ lbs and a 5x10 is in the 40-50lb range. I would have to double check my numbers though, was just talking with VP about this yesterday in reference to the EXO knuckles. Axial dropped down to a 5x10 on the front side I believe.
