Yall both need to build some scalers too. Lol"thumbsup"
Yea, but for some reason I prefer dumping money into the 1:1
Hi losihkid
just curiosity
When you say "....(use 1K resistor to GND to get middle state) " is the 1K resistor on the RX our in the servo?
Functions assignable to keys:
OFF - nothing
CHn - switch channel "n" value from one end value to opposite end
value. There is special handling for CH3 button. When using
3-position switch instead of CH3 button and momentary is
selected for this button, then centre 3-pos value will also
be detected and set to servo (use 1K resistor to GND to get
middle state)
Hi guys A quick question On steering mixes. Im fairly new to this but have a hacked GT3B with the new firmware. What im wondering is can I mix the steering so it adds a bit of right to the mix under acceleration? As the car torques a bit to the left in the dirt when you throttle up. And if its possible is it an easy process?
Thanks again
More infos about my issue :All is ok when not digging
