TK421
*EDIT* I forgot to post the build list...
Gspeed V3 Carbon
GSP skid
AR44 one-peice w/ SSD internals
Stealth X, forward spur, option 2 OD at 12%
G-LD CMS mount
MultipG panhard mount
IntheworksRC hybrid SS, Aluminum hi-clearance links
Modified SCX10.3 kit shocks w/ mini-t “front” springs
Mamba Micro Crawler
HH Snubnose V2 1800kv
Axial 56t spur w/ 11t pinion
Aluminum eBay beadlocks
PL KM3 4.7, vented at the tire w/ star cut stock foams
Flysky FS-GT5 w/ FS-BS6 rx
3s 1300 lipo
I think that's everything...
I think this thread is overdue for me. I started a V3 build back in early July. I've mostly been posting on the their FB group so I thought I'd share what I've done and where its at now.
I had originally purchased some Dravtechs for this build but ended up moving them to my VS4-10.3 build. I had the original shocks from the SCX10.3 and decided to fit them to the V3.
With the V3 being so much lighter, a spring change was in order. I decided to experiment with the Mini-T springs on here so I printed some spring cups and a cylinder sleeve to keep the springs in check. The end result is butter smooth I think it looks pretty cool to boot. Med up front w/ 30wt, firm in the rear w/ 32.5wt.
The next major change was swapping the Axial RTR 3 gear for a Stealth X. I don't mind the extra weight to add the 12% OD.
Took a break to play with some Wood PLA...
Lou
Gspeed V3 Carbon
GSP skid
G-LD CMS mount
Mamba Micro Crawler
3s 1300 lipo
Lou
