mmatthews
GMC TOPKICK
Pro-Line GMC Topkick body
Hot Racing Axial Scorpion Crawler Unibody SHD Differential Lock AX10
Hot Racing Axial SCX10 Scale Truck Hard Steel Center Gear set AX10
JunFac Carbon Steel Universal Shaft
AXI30563 Axial Universal Set AXI30563
Axial Rear Straight Axle Shaft Set XR10 (x2)
Axial Heavy Duty Bevel Gear Set 36T/14T
Axial Steering Knuckles Set XR10
Axial C Hub Carrier Set XR10
Axial Straight Axle Adapter Set XR10
Axial Steel Outdrive Set: AX10, SCX10 Transmission
Axial Solid Axle Set
FastEddy Axial SCX-10 Bearing Kit
Under drive gear AXI30402
Hot Racing spur gear 80t hard anodized
Holmes Hobbies TorqueMaster Pro 540 35T
Castle Creations CC BEC 10A Switching Regulator
Castle Creations 1/18 Sidewinder Micro Sport ESC
Axial Servo Horn
HITEC HS-7950TH MONSTER TORQUE SERVO,486 oz-in,PROGRAMMABLE,HIGH VOLTAGE
FS-GT3B 2.4G Transmitter w/ Receiver Combo FLY SKY 3ch
Biggin69 beef tubes
RC4WD dual spring 90mm black shocks
1.9 Out Croppers
1.9 Humvee internal beadlock wheels
3racing winch
Axial bumpers
Home made chassis mount servo plate
Better pictures to come. Build is really close to being finished. Hope to have it up and running this weekend. Still need to mount winch, add tool box behind cab, trim front fenders, add lights and I'm sure there is something else.
Axial Servo Horn
Biggin69 beef tubes
1.9 Out Croppers
3racing winch
Axial bumpers
