GMade picture thread
My g-mades....
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
First 10th scale build.
Custom tranny mount with all metal gear ax10 tranny
35t motor
junfac shafts
trianglated front
long radius arms in the rear
blitz wheels with tsl rubber
103mm piggybacks
upgraded cvs
Nice!! now go break stuff!! See if you can find a delrin skid so you can inboard your lower links instead of having them on the outside of your chassis. I can't remember who sells it for the stock R1 cage chassis but it's out there. Or if you have access to delrin and a bandsaw you can make your own. This will provide much better triangulation on the rocks and predictability when crawling. I'm loving that pair of rear lower trailing arms! see if you can match the front lowers with that aluminum design. I'm sure some vendor on here can fab one up for you on the cheap. Look in the vendors section under suspension.
What motor are you running? I see the rear trailing arms are dual shock mountable....do I see jumping in your plans lol!
This is my first post, and i send heartfelt greetings to the participants in this board.
27 T Tamiya lightly tuned Brushed with 16 tooth pinion gear (good choice for crawling AND speed)
320 A High Voltage ESC Brushed Speed Controller
7.2 V 3000 mAh saddle pack
XLD-45HMB BB Digital Servo 15 kg/cm
Front Wheels 300g
Rear Wheels 270g
Here's mine, one of my favorite.
MMP with a Tekin 9.5T redline and 4WS. Inverted the shocks for better LCG and to prevent leakage when not in use. It's for sale right now, but I'm considering making it a scaler.
Here's my R1 stealth before it got a brushless upgrade. It's now canibalized after the trans gear stripped twice.
Love this thread! Tons of amazing rigs that inspired me throughout this (my first RC) build.
RC Screwz Stainless Hex Hardware Kit (Must-have upgrade)
Delrin Skid Plate
Clearance Links
RC4WD R2D Trans
HB Rovers (white dot)
Double Deuce 5.5 Comp-Cut Foams (soft in front, medium in rear)
7 degree C-Hubs
Sidewinder SV3
Brushed Integy 55T
Castle BEC
FlySky 3-Channel RX with Hacked GT3B TX from Overkill RC
JunFac high clearance lower links
Axle-mount battery kit
GMade R1 rock racer
Gmade r1 kit
Junfac bent lower link
Junfac delrin skid
SS Screwz all around
Junfac led lights
Junfac shock brace
Shocks droop setup
Junfac alu servo/batt mount (not installed)
Proline beadlock
Rc4wd rock stomper xt 2.2
HH brxl/13t wp combo
Spektrum wp sr300 receiver
Hitec hs-5086 wp servo
Alu servo arm
Custom steering drag link
Junfac CVA kit
Custom panels
Tamiya wild Willy
And to come: alu knuckles/chub, junfac driveshaft
