GIVEAWAY!! Trakpower Power Supply
jdawg53
Illinois
Product Manual</TD><TD align="center" width="425" vAlign="top">
<TABLE border=0 width=400><TBODY><TR><TD vAlign=top width=200 align=center><TABLE border=0 width=180><TBODY><TR><TD align=center></TD></TR><TR><TD>The LED indicator light glows constantly when the on/off power switch is turned on. Using the adjustment dial, voltage output can be set from 11V to 15V — for DC current of up to 25A maximum between the two output terminals.</TD></TR></TBODY></TABLE></TD><TD vAlign=top width=200 align=center><TABLE border=0 width=180><TBODY><TR><TD align=center></TD></TR><TR><TD>The handy, detachable, color-coded terminal block lets you easily connect devices equipped only with large alligator clips. It can be placed away from the power supply for greater flexibility when working in crowded places</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
This is a giveaway for a
Trakpower 25A 12V Power Supply
Here is your chance to get a Trakpower Power Supply
FREE!
<TABLE border=0 width="100%"><TBODY><TR><TD vAlign=top>
TKPP5500
Input Voltage: 110-120V 60Hz (3-prong U.S. power cord)
DC Output Voltage: 11-15 volts, adjustable
DC Output Current: 25 amps maximum
Maximum Rated Power: 300W
Output Connections: 4 mm banana jacks with detachable terminal block
Overload Protection: 25A solid-state current limiter
Case Size: 5.5 x 7.2 x 2.5 in (140 x 182 x 64 mm)
Weight: 49 oz (1375 g)
Cooling: twin rear-mounted fans
TrakPower 25A 12V Racing Power Supply
A space-saving unit that delivers up to 25A maximum current
with dual DC outputs!​
Exceptional performance and convenience at an affordable price!​
State-of-the-art, high-frequency switching technology produces clean, smooth, reliable current​
Power two chargers at once — or a charger and tire warmer, discharger or other device — on dual output terminals​
DC output voltage can be adjusted from 11V to 15V as needed to operate all devices fully​
Capable of maintaining 25A continuous output current at 12V DC​
Two sets of 4 mm banana jacks are included for making easy connections​
Twin, rear-mounted cooling fans let you stack the Power Supply with other equipment to conserve space without restricting ventilation​
Built-in current limiter automatically prevents damage from accidental overloads​
Durable, lightweight case​
1-year warranty​
Giveaway ends May 8th.
You MUST be a star holding member.
Need a star? http://www.rccrawler.com/forum/payments.php
You may only enter once.
Item will only ship to lower US 48 states or an APO.
Post up a pick your rig this power supply will be helping charge.
Not necessary to win and winner will be drawn at random.
Thanks
J
