Gate check-in via smartphone
mikebecher
Big Island
This is an example of a system we'll be testing out to record gate check-ins for the http://www.rccrawler.com/forum/hawaii/568809-big-island-rock-race-numbah-one.html
The concept is that every race marker has a unique QR code and each driver scans it as they pass through.
After submitting a simple form, the driver number and time will be recorded for that marker.
We're not requiring the use of this system but it might be neat to see race results in real-time.
Try it out for yourself:
Scan this QR code and submit your response. If you don't have a QR code scanner, here's one for Android and one for iPhone
You can also click here to load the check-in form.
dsPQ9K.qr
Your entry will show up here.
*** Google only updates this embedded sheet every 5 minutes. To see results now, go to the live sheet ***
<iframe src="https://docs.google.com/spreadsheets/d/1hbm8ukfJU1dD8HpLjWJ55lig7wBANT8ySMvorvJ6Rqg/pubhtml?gid=1053622466&single=true&widget=false&headers=false&chrome=false" width="290" height="250"></iframe>
Pretty cool. I love anything technology related so this makes me giddy. :lol: I'm not a comp guy, but I've been involved in running one and this should make scoring a lot easier. Nice work.
I really really like the idea, but I do see a potential for problems. Over zealous drivers might scan early (scanning before passing through the gate). What if I forgot to scan one gate?? When I am out playing with my RC car, I usually silence my phone, or leave it in my vehicle, so having to pull it out at each gate would be, IMHO, a hindrance.
I offer this idea: model the gates after anti-shoplifting devices. Each gate is an electric sensor, so once your car breaks the plane of the sensor, its logged. Using the same idea as the stores, you can use the very small, light weight stickers (pretty sure they're just a weak magnet) and adhere them to a part of the car (you could go as far as putting everyone's sticker in the same general spot)!
Yup, there's loads of possible problems - no phone, no service, dead phone, scans not registering, forgetting to scan, rain, cheaters, and so on. We had a discussion like this a while back and everything was either too cumbersome or expensive.
This method was free to implement and will be optional. Drivers can check-in electronically or fill out their scorecards and log at every gate. They can cheat either way and failure to log a gate could result in a disqualification.
Automating gate check-in is going to result in someone figuring out how to defeat it no matter what. If we were to use anti-shoplifting type sensors, what keeps a driver from pulling the ID tag off the car or lifting the rig and just passing it through the gate? And then there's the cost. You would have to put a reader with power source on every gate, a tag on every car, and devise some sort of method to transmit all the data back to a central location. It's doable but unless Motorola is going to sponsor us, I thinks it's a bit beyond our budget.
