First Gen Toyota SCX-10
How does that rear suspension setup work for you? I was thinking of angling my shocks in towards the tranny plate for a little more articulation but I never thought of trying it like that. Is it stable?
It works great i think! Haven't been able to actually drive it like this yet but it gave me more articulation than the old setup and will still droop down to the old ride height. And it was free the way i did it so that is a plus too!
Finally got the new Novak system coming in the mail today should have it by Thursday I'm hoping! Upgraded to the goat 3s for just a little more money and hopefully this one won't crap out on me like the last one.
Can it do this with the new shock set up?
Cause this is some impressive side hilling! :shock:
Oh it easily will side hill this that wasn't even to the Max for the side hill. And should be able to do this easily now because it sits even lower now.
Finally! got the motor and new esc all installed and ready to go.
<a href="http://www.flickr.com/photos/49839190@N06/7757440226/" title="IMAG0667 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8284/7757440226_3a33b2b56e_z.jpg" width="640" height="383" alt="IMAG0667"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7757439960/" title="IMAG0668 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8307/7757439960_287c14bfe7_z.jpg" width="640" height="383" alt="IMAG0668"></a>
pictures of the flex now that everything is done.
<a href="http://www.flickr.com/photos/49839190@N06/7757439028/" title="IMAG0666 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8294/7757439028_d1c4058eea_z.jpg" width="640" height="383" alt="IMAG0666"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7757439282/" title="IMAG0665 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7262/7757439282_c4d807188d_z.jpg" width="640" height="383" alt="IMAG0665"></a>
Stanced!
<a href="http://www.flickr.com/photos/49839190@N06/7757439610/" title="IMAG0663 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8302/7757439610_a697bf198d_z.jpg" width="640" height="383" alt="IMAG0663"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7757440750/" title="IMAG0662 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8306/7757440750_0c3a844846_z.jpg" width="640" height="383" alt="IMAG0662"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7757441456/" title="IMAG0660 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8436/7757441456_5ce5ffd628_z.jpg" width="640" height="383" alt="IMAG0660"></a>
Now its time to get some pictures and videos of it wheeling with my friends!
its been a while! first of all i have the measurements for the rear links if anyone was wondering. the top links are the same and the bottom links are 3 1/4 inches from the ends of the link not including the screw on link ends just the solid link itself. and also i have pictures to explain how to do the spring setup i have for the rear that works with the drop bed.
Step one. you need to remove your old spring hangers from the rear. save one because you use it to make the new triangulated spring hanger in the very back.
<a href="http://www.flickr.com/photos/49839190@N06/7843043822/" title="IMAG0685 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7269/7843043822_85b77afc9e_z.jpg" width="640" height="383" alt="IMAG0685"></a>
Step two. What i did was ground off the actual spring hanger hoop all the way until all i had left was the three bolt holes and the body mount pin part.
then if you can see i drilled though the cross member in the very center and ran a long bolt all the way through it to connect the new spring hanger to the frame.
<a href="http://www.flickr.com/photos/49839190@N06/7843042820/" title="IMAG0686 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8304/7843042820_16063c5b9f_z.jpg" width="640" height="383" alt="IMAG0686"></a>
Step three. then you can go ahead and take the small bolts out of the axle ends and what i did was got longer ones and put a spacer in between the shock end and the axle so the shocks wouldn't get binded up at a weird angle. then just screw the springs into the ends of the axle and then together on your new spring mount. then all you have to do is cut down the body mount until you get the desired ride height. that is it and it is totally free!! hope this helps good luck guys! PM me if you have any questions and i would be glad to answer.
<a href="http://www.flickr.com/photos/49839190@N06/7843041816/" title="IMAG0687 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8304/7843041816_ef3550d919_z.jpg" width="640" height="383" alt="IMAG0687"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7843041026/" title="IMAG0688 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8293/7843041026_294c3f454b_z.jpg" width="640" height="383" alt="IMAG0688"></a>
<a href="http://www.flickr.com/photos/49839190@N06/7843040092/" title="IMAG0689 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7246/7843040092_38061e1beb_z.jpg" width="640" height="383" alt="IMAG0689"></a>
Again pm me with any questions you have.
so finally got my bumper all fabbed up all i have to do is make the frame mounts and figure out how to run the damn winch and i should be good to go for the front. still gonna make rock sliders and a rear bumper too but not for a little bit when i have more time! heres some pictures of the new cut front end and the bumper!
<a href="http://www.flickr.com/photos/49839190@N06/7843050268/" title="IMAG0678 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8300/7843050268_0a0593615b_c.jpg" width="800" height="478" alt="IMAG0678"></a>
no more chrome bumper for this yota
<a href="http://www.flickr.com/photos/49839190@N06/7843049142/" title="IMAG0679 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7132/7843049142_8ef237e8c6_c.jpg" width="800" height="478" alt="IMAG0679"></a>
New cut fenders too looks good to me
<a href="http://www.flickr.com/photos/49839190@N06/7843048210/" title="IMAG0681 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8444/7843048210_01e1dd740a_c.jpg" width="800" height="478" alt="IMAG0681"></a>
Flexed out on the new bumper
<a href="http://www.flickr.com/photos/49839190@N06/7843047110/" title="IMAG0682 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7131/7843047110_e80d836e7a_c.jpg" width="800" height="478" alt="IMAG0682"></a>
The bumper from the side
<a href="http://www.flickr.com/photos/49839190@N06/7843045846/" title="IMAG0683 by Donnie896, on Flickr"><img src="http://farm9.staticflickr.com/8291/7843045846_5cf309fd68_c.jpg" width="800" height="478" alt="IMAG0683"></a>
Somewhat what it will look like. Still need to paint it and smooth it out a little.
<a href="http://www.flickr.com/photos/49839190@N06/7843044758/" title="IMAG0684 by Donnie896, on Flickr"><img src="http://farm8.staticflickr.com/7280/7843044758_36f5c4d3ec_c.jpg" width="800" height="478" alt="IMAG0684"></a>
yeah...:flipoff:
