Time for some more Brono tinkering. I've been having a lot of fun driving this thing in 2WD in 2nd gear. I upped the gearing from a 14t to a 17t, and should probably go a few teeth more.
That being said, the poor Master Chief was getting thrown around too much, so I made him a zip-tie seatbelt:
I drilled not only through the seat base, but also through the structural webbing. This was to allow the zip tie to not interfere with the seat installation.
I also gave the Chief some side view mirrors from RC4WD. I painted them to look like brushed aluminum, and on they went.
Speaking of RC4WD, I also ordered the side marker lights for the ol' Bronco, and set about installing them. The existing marker light stickers provide the template for the holes you need to drill in the body:
After all of the holes were drilled and the lights test fitted, I painted the backing plates with the same aluminum paint to make them look metal:
I completely disassembled the body to install these so that I'd have room to work. While the body was apart, I also painted the headlight bezels on the grill to look chrome:
I also painted the exterior of the body with flat clear, but it almost makes no difference other than I won't have to touch up my paint so much. I also painted the interior with three coats; white, gray and black. The stock paint job is VERY see-through.
On to the wiring of my new lights. I used this old RC-Lights controller, which works great.
It's only supposed to power 10 LEDs, but I've got it doing 16. The benefit is that now only 1 wire needs to be dealt with when removing / installing the body. That also makes the lights a bit more dim, which is really good for the marker lights.
Now the underside of mtly interior has wires all over:
And the end result of this weekend's tinkering:
Lights off:
Lights on:
Those white LEDs in the marker lights are a bit too bright, even slightly dimmed. Some orange and red 3MM LEDs would probably look better. For now, I think the marker lights look better turned off.
Enjoy playing with your toy trucks! I keep hoping my 2nd gear bashing of this truck will break something, because then I'll need to fix / upgrade it. But no such luck yet. Just lots of drifty, bumpy fun with some occasional crawling. The red light in the background of these photos is the heat lamp for my daughter's chickens.
