Another weekend of tinkering is almost in the books.
I started with trying to get the weight from the electronics centered between the chassis rails. I didn't like how the ESC was on the passenger side, and my drivers side either held a heavier battery, or nothing.
The Canucks at GCM Racing did a 4 video series on the Axial 10.3 Bronco. In video #1 they do a front mounted battery mod. I copied that, but used the tray to mount my ESC.
I had to buy a 6 inch servo wire extension to make the shift servo connection to the ESC. I ran all of my wires under the faux-engine.
Then I moved my power switch to the leading edge of my front fender liner. I used very short screws that don't poke through into the wheel well. I can just barely touch the switch enough to use it with the body attached, but it is still invisible.
Now I run a 2200MAH 3S on the rear tray to shave some weight over my old 5000MAH.
Since I shaved some weight above the axles, I decided to add some more back, and higher up! I ordered the aforementioned 6 inch servo wire extension from RPP, I also bought some sand ladders and a steel, functional Hi-Lift jack.
The sand ladders just stuff right under the spare, between my gas cans. No thought needed.
Mounting the Hi-Lift jack took some thought. I eventually settled on using the shock caps from the SCX10 faux reservoir shocks.
I attached those caps to the locations where the spare tire mounts attach to the cage. I just needed some slightly longer screws and some flat washers. Then I pass a 1.5mm screw through the jack and into those little bosses that the faux reservoirs mount on.
That's it for now. I hope to get this truck out for some driving tomorrow, with two of my sons. I'll probably keep slowly filling the bed space up with more scale items.
I happened to figure something out with making my tire lettering marking last longer. Thick coats of paint get hard and brittle when they dry. The flexing of the sidewall throws the paint off when done in thick coats. One light coat of paint remains flexible. It doesn't look as bright, but it sure does last longer.
