mikemcE
Canceled mine..... no way the two speed fits
Hang up and Drive
Hang up and Drive
Ordered one today.... found it for $123. Shipped.
I don’t know about the two speed , I will find out!
Hang up and Drive
Where at? I don't plan on using 2-speed so I might pick this up.
Hang up and Drive
Do you know that for fact? What about it won’t fit? It has holes for the shifting servo. I don’t see why it wouldn’t “fit”.
No I don’t. I really like this, but I do run the two speed, I’m not seeing the servo mount for the two speed
None of the pictures show that side
Hang up and Drive
The only thing keeping me from pulling trigger is that I'm uncertain how prone it is to getting bent out of shape.
If you were to somehow land the chassis on a rock or something similar really hard, would it bend? I'm sure it's probably ok and probably unlikely though.
I don’t know how the chassis does as far as that, but it is definitely well built and is pretty thick. I’ll try measuring it tonight in a few places to give you a better idea
That would have to be one hell of a hit to bend that thick, aluminum plate!
Have you ever heard of paranoia? :lmao:Yeah, it's highly unlikely, but you never know.
You probably also need to be selective in what other pieces you use as well I would guess since this chassis is not going to flex like the stock chassis.
For ex:
Rear link mounts - what would give first... the trailing arms or link mount depending on which trailing arms you use.... SSD vs Vanquish. The chassis should be the most rigid, so it's either bending the trailing arm by Vanquish, or a tie-rod end for the SSD. What if the Vanquish trailing arm is used and the truck gets hit in an odd way would there be a risk of the link mounts getting bent?
I could just also be worrying over nothing!![]()
Yeah it could bend. Yeah the world could end. Will it anytime soon? Probably not.
Exotek makes top notch stuff. Lots of people call Vanquish top of the line in the crawling world. Exotek is above that and they have the customer service to back it up.
Keep us updated on how it performs. Really interested to see how it affects the handling of the Yeti.
Looks good, will a full size fit ? Looks like just 2 screws?
Hang up and Drive
Nice!! Can you tell me what model servo that is and how you mounted itMini servo for shifting “fits”
